Mid 2012 model, A1278 / 2.5 GHz i5 or 2.9 GHz i7 processor.
1624 Questions View all
Keyboard stuck in Caps after coffee spill.
So I accidentally spilled coffee over my MacBook Pro, I turned it off immediately and a couple of houes later I turned if on again and the keyboard it's stuck in Caps. I decided to turn it Off again. What could I do?
These are my MacBook specifications
1 Comment
It would be helpful to know which MacBook Pro you have. Paste your systems serial number into this web sites lookup: EveryMac - Lookup, then paste the systems URL into your question so we know which model you have.
by
Add a comment
1 Answer
Chosen Solution
Sadly it's going to take some effort to fix this as you'll need to take the keyboard out to properly clean it or your other approach is just replace the uppercase.
As you didn't tell us which model we really can't give you more.
In the mean time turn off your system and don't charge it! Keep it cool as well until we can then guide you how to take your system a part.
Update (11/30/2016)
Here's the IFIXIT guide you'll need to follow: MacBook Pro 13" Unibody Mid 2012 Upper Case Replacement. Once you get the uppercase off you can try to take the keyboard out to clean or you could just replace the fully assembly.
Let us know which direction you'll be going once you decide.
Score 1
Add a comment
Add your answer
Gilberto Solorza will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 2
All Time: 2,328
