Second generation of iPhone. Model A1241 / 8 or 16 GB capacity / black or white plastic back. Repair is more straightforward than the first iPhone. requires screwdrivers, prying, and suction tools.
1169 Questions View all
Why is my volume up button switch not working?
my volume up switch doesnt work but when i hit volume down it works perfect. what shoud i do? i've ordered a new switch but i cant find anywhere on how to install or if its even that issue.
Score 1
Add a comment
Chosen Solution
well, - this - is the part and
the instructions are here
You need to relace the ribbon cable as the volume buttons/switches are attached to it
all the best
iPhone 3G/3GS Headphone Jack Assembly Image
Product
$14.99
Add a comment
Most Helpful Answer
Go into settings-- sounds Press the home button and the same time press the volume up button. It will bring it back like magic. I had the same problem and now it works.
Score 1
Add a comment
YOU MIGHT NEED TO LONG PRESS THE CURRENT ONE THAT'S NOT WORKING. I AM FACING THE SAME AND AFTER A LONG AND CONTINUE PRESS, IT WORKS LIKE CHARM.
JUST DO LONG AND LITTLE HARD PRESS ON IT.
THANKS.
kunjalmca@gmail.com
Add a comment
Add your answer
jokedawg95 will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 3
All Time: 13,679
