Repair information and guides for the iPhone 6 that was released on September 19, 2014. Model Numbers: A1549, A1586, and A1589
Broken home button flex cable
I have a broken flex cable on my iPhone 6 home button. It's completely cut in half. Is there any way to repair? I didn't do this. LOL Im a repair guy. This is shoddy work a customer wants me to try and fix. Error 53 is solved BTW right? Honestly haven't had issue with error 53 before, so I suppose it sounds like a stupid question.
Score 2
6 Comments
Does he want the fingerprint scanner to work? If not just use a aftermarket home button.
by
That was my first suggestion... He would like to restore the touch ID
by
Error 53 is destroyed. No need to worry about that at least. Realistically it is not worth fixing the home button cable.
I know it's possible by transferring the NXP chips from one genuine home button to another but that is on the iPhone 5s at least.
by
Hi @benjamen50. I've seen this statement floated around a few times of late yet I cannot find anything or anyone who shows they can do this. Do you know this for certain? I'd love to learn more.
by
I have the same problem and I will try to fix it. ;)
by
Show 1 more comment
Add a comment
Chosen Solution
Realistically, no it is not possible.
You are unfortunate that the tear is so close to the actual button. In theory, you could re-establish the connections that were severed . In reality, there are 6-8 connections on a flexible mylar strip only a few millimeters wide and you have very little flex to work with.
This would be a super challenging task for a very experienced micro-solderer. This is clearly not a DIY repair.
Score 1
3 Comments:
Ok. It's not impossible. And this isn't really a data connection. What is this repair called? So I can inquire on getting a quote and contracting this repair out. Thank you.
by
how does a screen repair at the apple store solve a broken home button?
by
Ask around for repairing a torn home button flex. To be honest, depending on your location, it will probably be more cost effective to go to the Apple store and have a screen replacement done; they may replace the Home button at the same time
by
Add a comment
I hear that Apple can in fact repair these. If you can send them the device they have tools that can (supposedly) recover keys from a dead button but its not cheap.
There are actually ways to DIY this but still working on it. I had some success using an X-ray device of my own design on memory chips with similar geometry but this is extremely dangerous and only works with an original button. Effectively the code inside is stored on a PROM which lacks an erase window so X-rays of the right intensity can wipe it making the ‘phone’ recognize it as a new button in Apple’s Horizon Machine but to actually re-code the button again needs a lot of effort.
Swapping button with a phone containing a matching serial range is possible and others have reported success with this method earlier but YMMV. Generally speaking the closer you can get the serial the better chance it has to work.
3 Comments:
Andre, this sounds totally overdone. Why erase the ROM DIY only to have to use an Apple Horizon machine (which only Apple has) to program it. Apple just replaces the Home Button (they do not fix them) and programs it...easy-peasy...as part of a screen replacement. No need for dangerous x-rays or any other convoluted repairs.
by
Actually this is so a "blank" button will then work. Master reset seems to reactivate these according to what I can find online but only if they are blank from the factory. This process will of course wipe the phone but if the alternative is a very expen$ive repair..
by
@bejamen50 how do you fix the iPhone 5s broken flex
by
Add a comment
Add your answer
Krazy Kat will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 18
All Time: 7,143
