stuck on apple logo
Hi guys
my iphone 5s stuck on apple logo after it dropped on the floor.
i tried to recover it by using home and power keys at same time. but the problem is exist.
Hi guys
The physical drop clearly damaged something inside your phone.
You may be lucky; it could simply be a flex cable that partially unseated from its connector due to the impact. If you feel confident, open your phone (you will need a special screwdriver) and follow the directions for the 5S display assembly replacement guide.
Be very gentle as the flexes and connectors are delicate. Re-seat everything and try the phone again. If it doesn't solve your problem, you may have some logic board damage that will need to be looked at by a qualified repair shop that does micro-soldering.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 124
