The Kenmore 90 Series is a washing machine manufactured by Kenmore.
Why isn't my washer agitating but will still spin out?
My washer won't agitate but still spins out. Last load threw it off balance and I'm not sure where to start looking for the problem. Please help. Model number is 110.26912691
Score 1
1 Comment
Sounds like you have a alligator dog problem there should be answers on this website how to fix it the top of the agitator spins freely in both directions it is a dog issue
by
Add a comment
1 Answer
Chosen Solution
Cause 1
Agitator Repair Kit
If the washer won't agitate, replacing the agitator repair kit may solve the problem. The kit contains the agitator components that are most likely to wear out and/or fail. If any of the parts are worn out, stripped, or damaged, replace the kit.
Cause 2
Drive Block or Bell
The drive block connects the washer transmission to the agitator. If the drive block is worn out, the transmission shaft will still move back and forth, but the agitator will only move slightly or will not move at all. Inspect the drive block for damage. If the drive block is worn out, stripped, or damaged, replace it.
Cause 3
Motor Coupling
The motor coupling connects the motor to the washer transmission. If the washer is overloaded, the motor coupling will fail in order to protect both the motor and transmission. The motor coupling can also fail due to normal wear. Inspect the motor coupling to determine if it is broken. If the motor coupling is broken, replace it.
Score 2
Add a comment
Add your answer
Christine will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 6
All Time: 1,004
