Repair information, troubleshooting tips, and guides for the sixth iteration of Apple iPhone, announced on September 12, 2012. Model: A1428, A1429
2522 Questions View all
Philips 1.2mm screw badly stripped. help!
I was repairing my iPhone and I came across the final screw that allows to remove the shield to the LCD connectors. Then, it strips. :(
I've tried everything to a rubber band and super glue, using a different screwdriver and such, and all it did was strip the screw even more! The head of the screw is now in the shape of a square.
So any suggestions? I haven't used a drill or dremel or screw extractor as it is my last resort, so any other ideas would be great.
Score 1
Add a comment
1 Answer
Chosen Solution
Rachel, The heads of the screws are pretty soft, try a mini set of vise grips clamped on the head or you can try cutting a slot in the head of screw to accept a slotted screw driver enabling you to turn out screw. As a last resort you may have to cut the head off with a dremel like tool and use pliers to pull up on screw shaft while spinning out. Good Luck.
Score 2
Add a comment
Add your answer
Rachel Harper will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 4
All Time: 671
