Can I replace a flywheel on a automatic transmission
How do I replace the flywheel on a 1994 1500 GMC truck
Mel Fritzen, I posted a couple links below, 1st link is showing the process and the other links talk about the process with some tips and tricks. Depending on your mechanical ability, tools and equipment you have access to and a good strong partner would help, you could do the flexplate change yourself. Work carefully, support vehicle securelly and remember it can be a heavy/dirty job if you do have to drop the transmission to do the change. Good luck.
https://www.youtube.com/watch?v=J4B_Umn7...
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 4
All Time: 643
