Repair information and guides for the sixth iteration of Apple iPhone, announced on September 12, 2012. Model: A1428, A1429
2517 Questions View all
Do I have to re-put the adhesive strip for the battery?
I recently disassembled an iPhone 5c to replace the battery. It didn't have adhesive strips but instead it was simply glued, so I just took it off by force. The phone is working now, and the battery is in place.
My friend has 3 iPhones: 5, 5S ,5c. However, I am afraid that I'll need to also buy adhesive strips for the battery. Is this obligatory? Can I just put the battery and connect it? And was it bad that when i put a battery in the iPhone 5c I didn't glue it back?
Score 3
Add a comment
Chosen Solution
You should be using some sort of adhesive so the battery doesn't move around while it's installed in the phone.
Because if there is little to no adhesive you risk having the volume / power button ribbon / flex cables being cut from all the friction caused by the battery moving around. There is even a chance for the battery ribbon cable to be cut from this too.
Additionally if these phones came from clients or customers the chances are you will see them come back and complain about the battery moving because they can hear and feel the battery moving around.
You have a few options on what kind of adhesive you want to use.
The cheap quality one is just black double sided tape from eBay, next up is red tape (transparent adhesive) which you can also buy from eBay.
The best quality ones are the tesa tapes or 2x adhesive battery strips.
That's why I always come prepared with a decent amount of adhesive for battery or screen replacements without frame pre installed.
Edit: If you were asking about reusing old adhesive, it's highly recommended that you do not as they weaken a lot after being used once.
Score 14
4 Comments:
Thanks. By the way, I replaced my iPhone5c battery. It didn't have an adhesive strip but was glued. I just re-put the battery. It this also bad?
by
And can I just use superglue?
by
dont use glue. use some kind of dubble adhesive tape.
by
Superglue is a really bad idea. The next time you need to remove the battery it's going to be really hard and leave residue / difficult to remove.
Using hot-glue or b7000 glue is also not a good idea to use as adhesive for batteries.
by
Add a comment
is one adhesive strip enough? i went to a repair shop and have my battery phone fixed, i bought battery online from a legit shop and it came with two strips, but he cut it, put one to my battery and keep one.
Add a comment
Add your answer
AbAppletic will be eternally grateful.
Past 24 Hours: 2
Past 7 Days: 14
Past 30 Days: 77
All Time: 22,751
