Fourth generation iPhone. Repair is straightforward, but the front glass and LCD must be replaced as a unit. GSM / 8, 16, or 32 GB capacity / Model A1332 / Black and White. This page aims to help users troubleshoot, fix, and seek help for the iPhone 4.
2375 Questions View all
How to flip up home button ribbon cable retaining flap
When putting a new home button flex cable in, do i need to pry up the retaining flap that connects the flex cable or do i just slide it in. im afraid the snap the plastic
Score -1
Add a comment
Chosen Solution
Yes, you need to pry it up with your fingernail or a plastic opening tool, as described here. Be gentle. After you pry it up, push the cable in, then push it back down like it was when you started.
Score 1
Add a comment
my retainer doesn't hold the cable back..is that normal? i can pull out the thin home button cable, while the retainer flap is down
Add a comment
Add your answer
John will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 1
All Time: 1,892
