Model A1311 / Mid 2011 / 2.5 & 2.7 GHz Core i5 or 2.8 GHz Core i7 Processor
429 Questions View all
Pimp my 2011 iMac
Hello.
I have a 2011 21.5" iMac that I wish to upgrade.
I already upgraded it to 12gb of RAM but it'a still not fast enough.
I wish to install an SSD and power macOS from it, and upgrade the AirPort Extreme card (maybe add the solution of OSXWiFi) to add continuity and handoff features.
Is it possible? Can I do it by myself or should I contact a lab? Are there any more upgrades that could "Pimp my iMac"?
Thanks in advance!
Score 1
Add a comment
1 Answer
Chosen Solution
To start with you can add in a SSD. Here is the IFIXIT guide you'll need to follow: Installing iMac Intel 21.5" EMC 2428 Dual Hard Drive Kit. Once done you can prep it up to be your boot drive and place your apps on it for its speed, leaving your HD in place for your content files (text, images, music, vids, etc...)
Before you migrate your apps over to the SSD you should cleanup the old cache & log files, using an app like this makes quick work of it: DiskDoctor
After you have things setup I would recommend you run Disk Utility to test out your HD once you are booting from the SSD. As well as running a good defrag'ing app on your HD like this one: Drive Genius
Reconfiguring your WiFi & Bluetooth services so you can use Continuity & Hand Off can also be done. You'll need to replace the WiFi adapter and run an extension cable to where the Bluetooth board is (removing it) to the new combo WiFi/Bluetooth board.
I do wonder if its worth it and if all of the possibilities will work here. I would wait until some details on what you are looking for have been proved to work on the older modified systems under MacOS Sierra.
Score 2
2 Comments:
Thanks for the great answer.
Is there a website or a forum thread that could provide me the compatibility information of macOS Sierra with my mac?
by
Sadly, none exits at this time point. There are Apple TN's and other sources on what the officially supported systems offer.
So far the only thing that I might use was AppleWatch login, but I'm not that paranoid ;-}
by
Add a comment
Add your answer
Ofek Inger will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 3
All Time: 703
