BlackBerry's newest flagship that features a physical keyboard.
73 Questions View all
Phone not switching on after water damage pls help
Had dropped my blackberry passport in water during a party removed it out and tried to switch it on but it didn't and is now dead. Yesterday I plugged it into the charger the led blinked the red light but today nothing happened I really don't have money to buy a new main or the motherboard pls help on how to get it on and back to life pls help me friends pls
Add a comment
1 Answer
Chosen Solution
Hi,
As you know water and electronics and electricity are not a good mix.
The water causes corrosion and provides circuit paths for the electricity which were not in the phone's operating design and could damage the components.
First do not turn on your phone and then you need to remove the battery as soon as possible from the phone to minimize further damage.''
Then you need to dis-assemble the rest of the phone and clean all the affected parts using Isopropyl Alcohol 90%+ to remove all traces of corrosion and water. Do not use "rubbing alcohol" as in some cases this is only 70% and is not as effective. If you do check the label to verify the amount
Here is a link that in general, describes the process.
Electronics Water Damage
You will probably have to replace the battery as it is very hard to recover a battery from water damage.
As always with electronics, especially surface mounted PCBs be gentle when handling and especially when brushing away the corrosion. You do not want to remove any components from the board.
Hopefully after you have done all this the phone might possibly work correctly again.
Here is a link to a guide which shows how to dis-assemble your phone.
http://www.myfixguide.com/manual/blackbe...
If this process seems too daunting, take your phone to a reputable, professional phone repair service and ask for a quote for a repair. If you decide to do this, do it sooner than later.
Score 1
Add a comment
Add your answer
ARYAN BHASIN will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 1
All Time: 384
