The fourth-generation Surface Pro tablet, released October 26th, 2015.
208 Questions View all
Videos do not run well on powerpoint
I insert videos to my powerpoint presentation (embedded). Use all kin of formats (WMV, mp4, avi....). If video is small and I enlarge it to fit frame or even just a little bit - the video does not run smooth
Add a comment
1 Answer
Chosen Solution
Hi,
This link may be of interest to you, regarding your problem
Click on Optimize media in your presentation for compatability
https://support.office.com/en-us/article...
Score 2
2 Comments:
I already did it several times with a variety of formats and resolutions - it did not work. the videos still jump and have occasional delays (most of them).
I also tried to resize the video display - small display do better but problem still exists
Same powerpoint presentations with same videos work very well on all other computers
by
Hi, Two more things to try if you hadn't already done so.
1. Try disabling 'Hardware Acceleration' in Powerpoint.
Click the File tab. Click Options, click Advanced in the left pane of the PowerPoint Options dialog box, and then under Display, ensure the Disable hardware graphics acceleration check box is selected. if it is already disabled, try enabling it by unchecking the box.
2. Ensure that your video drivers are up to date. Go to Device Manager (press Win key + x key together, a box will open on left of screen, click on Device Manager) > click on arrowhead next to Display Adapters to expand entries, right click on your display adapter (should be an Intel brand) and click on Update driver software and follow the prompts.
Do ordinary videos run smoothly on your laptop?
by
Add a comment
Add your answer
Assia will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 4
All Time: 9,250
