Repair and disassembly guides for HP printers.
1090 Questions View all
hp ink system failure
The ink cartridges are intact and unable to determine the issue.
This pops up on the screen, "There is a problem with the printer or ink system. Turn printer off, then on. If problem persists, contact HP.
Score 1
Add a comment
Most Helpful Answer
Odalys Lorenzo if you are not using original HP cartridges it is possible that this is related to the scam that HP is pulling with their firmware. HP has it programed in the firmware for non-HP cartridges to fail at a certain date and for the printer to not recognize 3rd party cartridges. This is not just on recent firmware but has been there for a while.
Score 2
1 Comment:
I agree!
I have an 8100 HP. 2 1/2 years ago I purchased new HP cartridges from Costco, Staples & Officedepot; none would work with my printer (I was using 950 & 951 cartridges). I contacted HP & they said that I needed to replace it with a new unit!!! That “po’d” me.
I then did extensive research in the web & found that the big-4-printer manufactures have placed software on their printer drivers to not read them! I then went to Costco with my empty cartridges & had them refill them (with new chips). I have been using these refilled cartridges for 2 years... recently it will not print due to “printhead: missing, failed or incompatible” error. This is clearly a new campaign to get us to buy new. Sooo sad.
Any one out there with a work around to clear this error? I’ve unplugged, tried reset; from machine & from computer software, etc. I hope someone out there can help or send me somewhere to fix it.
by
Add a comment
Hi Odalys.
Thanks for posting this question. I never imagined I'd be answering HP questions here but I am glad to do so. I served for 15 years at HP as a Tier 1, Tier 2 and Tier 3 Technician, with a specialty in Inkjet Printers (1999-2014). Basically, I'm an HP Printer Subject Matter Expert.
Frankly, I wish I had better news for you. It's time to replace your printer. If you have already turned it off and on, removed the power overnight and tried turning it on again, its likely that the printhead itself within the printer has failed - electrically.
Unfortunately HP doesn't design their consumer printers with repairability in mind.
Sorry to be the bearer of bad news,
Loren
Score 1
1 Comment:
Thank you for your response.
by
Add a comment
I have, through multiple occurrences, determined that soaking the print head in a small pan of isopropyl alcohol will remove the clogging ink. I soak the print head for about 1 hour then dump the dirty liquid. Soak it again, then dip it multiple times allowing the liquid to drain. The liquid should be nearly clear. Dispose of the liquid and use paper towels to dry the print head. Tap it gently on the slot side to help get the liquid out of the interior.
Add a comment
I have had an 8100 HP for 4+ years. 2 1/2 years ago I purchased new HP cartridges from Costco, Staples & Officedepot; none would work with my printer (I was using 950 & 951 cartridges). I contacted HP & they said that I needed to replace it with a new unit!!! That “po’d” me.
I then did extensive research in the web & found that the big-4-printer manufactures have placed software on their printer drivers to not read them! I then went to Costco with my empty cartridges & had them refill them (with new chips). I have been using these refilled cartridges for 2 years... recently it will not print due to “printhead: missing, failed or incompatible” error. This is clearly a new campaign to get us to buy new. Sooo sad. I believe you were caught by HP’s web; attempting to force you to repurchase another printer. Throwing away a perfectly good unit!
Add a comment
For HP printers not allowing use of non HP cartridge, giving you the "non HP chip detected" message, try the following:
Go to https://www.reddit.com/user/DaveJhonson2...
and download the downgrade/reversion of the firmware for your printer and run it.
Then go here to follow instructions for making sure your printer isn't set to auto update: https://www.cartridgepeople.com/info/hp-...
Worked for me. It's the latest firmware that causes the problem.
Add a comment
Add your answer
Odalys Lorenzo will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 2
Past 30 Days: 2
All Time: 1,657
