Repair information and guides for the Apple iPhone 5s that was announced on September 10, 2013. Model: A1533, A1453, A1457, A1528, A1530, A1518
3530 Questions View all
Odd behaviour from the headphone jack
SO, my headphone jack on an iphone 5s is acting rather strangely:
When i plug a headset/headphones in and listen to music it's absolutely fine, but when someone calls and i pick up, or when i call out then it wont pick up sounds, and im not able to hear the other person, again this is with the headset plugged in, and i've tried 5 different headsets.. Oh and the thinteg drains battery rather fast despites testing a couple of new ones, so everything sort of pointing to a short, i just cant find it.
The device is using IOS 10, if it matters .. But my guess would have to be a bad component on the motherboard.. Anyone encountered this problem before? Because i feel that swapping out the headphone jack assembly is a redundant solution that wont work here I guess..?
Add a comment
Most Helpful Answer
I would try changing the port/headphone assembly as this is probably the easiest/cheapest option.
Score 1
Add a comment
Hi! does sound play after you take the headphones out? If it doesn't, try cleaning the port with compressed air. You can also take a q-tip, remove the cotton and then push it into the port (not forcefully), you might feel a "click" when you push it in past a certain point. Otherwise I have no sollution.
Add a comment
Add your answer
salesblock will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 3
All Time: 67
