Everything you need to repair your iPhone yourself! From the newest iPhone 15 lineup, all the way back to the original iPhone 2G released in 2007, iFixit has free repair guides and disassembly information for every single iPhone, as well as the best replacement parts, tools, and tips in the galaxy.
36478 Questions View all
Unexpected error 9 iTunes
I have an iPhone with cracked glass that don't power-on (even backlight).
If i simple connect to iTunes, i receive the message that a restoring is required (recovery mode, i can see the IMEI).
I've tried restoring it in DFU, recovery mode, and both ipsw firmware iOS 9 and 10, all with the same result - iTunes keeps throwing error 9
Also noticed that if i keep the iPhone just connected to the PC (without doing anything), it will disconnect and reconnect automatically every certain amount of time.
I've also tried this solution: How to fix iTunes error 9
With those results:
- Reiboot (http://www.tenorshare.com/products/reibo...) = Stuck at "Exiting from recovery mode, please wait..."
- i4Tools (http://www.i4.cn/) v.7.10 = Error at 15% (Step: NORData)
Any ideas/help would be appreciated.
Thanks in advance.
Add a comment
1 Answer
Its NAND IC fault>>>
Add a comment
Add your answer
Luca Pastrani will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 3
Past 30 Days: 3
All Time: 616
