Compatible OS for the iMac Intel Core 2 Duo, 2.16 GHz
Need to know what OS is compatible with an iMac Intel Core 2 Duo – 2.16 GHz with 2 GB Ram. I have never owned or used a MAC computer. I have always used a PC running some version of Windows. I am also so curious why it seems that Mac's use such low Ram? ~ Thank you!
1 Comment
Thank you Mr. Mayer. You guided me to discover the information that I needed in order to get the answer.
by
Add a comment
1 Answer
Chosen Solution
I really don't know your exact machine (the Axxx and EMC # are on the bottom of he stand if you would like me to be more exact.
The machines with that processor came out in 2006.
I'll pick the 17" and give the stats on that one.
RAM Type: PC2-5300 DDR2 Min. RAM Speed: 667 MHz
Details: Supports 667 MHz PC2-5300 DDR2 SDRAM (200-pin SO-DIMM).
Standard RAM: 1 GB Maximum RAM: 4 GB*
Details: 1 GB of RAM is installed as two 512 MB SO-DIMM modules.
*Apple officially supports 3 GB of RAM, but third-parties have been able to upgrade the system to 4 GB of RAM using two 2 GB memory modules with some limitations.
Pre-Installed MacOS: X 10.4.7 (8K1106) Maximum MacOS: X 10.7.5*
Score 3
Add a comment
Add your answer
Steven Williams will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 9
All Time: 2,120
