Broken screen - touch function didn't work before or after repair
Hi,
I'm repairing an iPod 3rd Gen that came to me with a broken screen. The touch aspect didn't work.
After replacing the screen/digitizer, the touch aspect still doesn't work. I've double and triple-checked the cable and am pretty sure I have it in right.
I have also tried hard resetting, restoring, multiple times.
Any help?
Thanks in advance.
Score 1
1 Comment
I just gave up... nothing I could find. I assume the drop damaged the logic board.
by
Add a comment
1 Answer
Chosen Solution
If the touch screen doesn't work, then either the digitizer is broken, or the connection is bad, or the logic board is broken.
If you've already tried replacing the digitizer, then disconnect the cable and examine the connector on the logic board with magnification, and see if you see anything you can fix. If not, then you'll have to replace the logic board.
Score 2
Add a comment
Add your answer
spacec0w will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 3
All Time: 2,200
