Repair information and guides for the Apple iPhone 5s that was announced on September 10, 2013. Model: A1533, A1453, A1457, A1528, A1530, A1518
3530 Questions View all
blue screen on boot
when phone boots it shows a blue screen for three seconds then goes to the lock screen. Phone then works for a while, then screen gets cloudy. Any ideas? Phone is running ios 10.0.2 and was doing this since 9.3
Add a comment
1 Answer
Chosen Solution
Has the phone been repaired before (e.g screen replaced)?
Usually for screen going cloudy it's either long screw damage (When the longer screw out of the 3 for the metal plate covering the front screen cables are used on one of the lower two screw holes) or a damaged LCD ribbon cable / connector / or faulty screen (usually due to physical damage).
The last time I had this issue with the screen going cloudy it was due to a faulty screen (LCD connection was bad).
Score 2
1 Comment:
thanks Ben, but phone was never fixed before, and Verizon ended up replacing it
by
Add a comment
Add your answer
Michael J Driscoll will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 87
