Repair information and guides for the Apple iPhone 5s that was announced on September 10, 2013. Model: A1533, A1453, A1457, A1528, A1530, A1518
3530 Questions View all
Home Button not working and the touch ID works
I saw on the comments that doing a hard reset will solve the problem touch id works but home button is not working after replacing the battery
How to hard reset my iPhone 5s without having the home button working?
Add a comment
1 Answer
Chosen Solution
Turn the phone off and on via power button slide to turn off (this alone should get it working).
If that does not work then try resetting network settings, update iPhone via iTunes.
Otherwise unplug battery after turning off and plug it in again and plug in home button cable, whichever is more convenient for you.
Just make sure after replugging the battery that the home button cable is plugged in before you turn the iPhone on.
Last resort is to restore the iPhone via iTunes.
For all I know it could be a partially teared home button cable.
Score 2
1 Comment:
I did the reset after changing the home button and the dock and still not working
i did a backup restore and now i cannot unlock the screen because the new update required pushing the home button :(...
by
Add a comment
Add your answer
coopers91 will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 1
All Time: 467
