Why when my lawnmower gets hot it turns off
Why when I use my lawnmower for 5minutes it gets hot and turns off and when it cools down it dose it again could it be the coil?
Albert, A lot of lawn mowers have a problem with the gas cap not venting properly and will quit running after running a few minutes as you described, try running with cap removed or very loose( be-careful of splashing fuel).
Other things that could cause this issue are bad fuel, weak/colapsed/kinked fuel line, faulty spark plug, faulty ignition/coil, oil over full, clogged air filter, plugged/dirty carburetor, worn engine parts internal rings/valves/etc.
Here is a link to explain how to fix your mower. Tap on or click on the blue link. I hope this helps. Good luck!
I have been fixing a JD 14sb with a kawasaki fc150v engine, it was just shutting off every time it got hot. It seemed electrical but there was always a spark. Turned out it was the igniter on the side of the engine which controls the timing of the spark. Took me a long time to isolate this fault. Hadn't come across this part before, thought the timing of the spark was simply controlled by the flywheel magnet passing the coil.
Past 24 Hours: 71
Past 7 Days: 426
Past 30 Days: 1,648
All Time: 49,178
