Repair guides and support for gas, electric, and human powered machines used to cut grass, whether push style, or ride-on.
878 Questions View all
Why when my lawnmower gets hot it turns off
Why when I use my lawnmower for 5minutes it gets hot and turns off and when it cools down it dose it again could it be the coil?
Add a comment
Chosen Solution
Albert, A lot of lawn mowers have a problem with the gas cap not venting properly and will quit running after running a few minutes as you described, try running with cap removed or very loose( be-careful of splashing fuel).
Other things that could cause this issue are bad fuel, weak/colapsed/kinked fuel line, faulty spark plug, faulty ignition/coil, oil over full, clogged air filter, plugged/dirty carburetor, worn engine parts internal rings/valves/etc.
http://www.repairclinic.com/RepairHelp/H...
http://homeguides.sfgate.com/mower-stop-...
Score 2
Add a comment
Here is a link to explain how to fix your mower. Tap on or click on the blue link. I hope this helps. Good luck!
https://m.youtube.com/watch?v=gZxswm061O...
Add a comment
Add your answer
Albert loves Retta will be eternally grateful.
Past 24 Hours: 9
Past 7 Days: 76
Past 30 Days: 397
All Time: 1,661
