The Nintendo 2DS is a handheld gaming device developed as an entry level version of the Nintendo 3DS with nearly identical hardware, but without the 3D upper screen function.
205 Questions View all
Nintendo 2ds problems. Help!
So the problem with my 2ds is that if I turn it on it will not show anything and just power off two seconds later. It was working 20 min prior to this and nothing happened to it at that time. Please help! Ok new development the screens flash and you can hear a small pop from the speaker and then it just shuts off.
Add a comment
This may help: dsi flashs on and then turns off
It's a different model, but being a Nintendo DS, I'm sure the issue is somewhat relatable to yours.
2 Comments:
Ok it may be the same problem but do you know where I can get a guide for my model?
by
It may be the same problem but do you know where I can get a guide to fix it for my model?
by
Add a comment
Hi,
The little pop is telling you that the unit is in short circuit. Possible causes:
- Broken screen (only way to verify is replacing the screens)
- Short circuit fuses (F1 a/o F2) - multimeter and check for continuty
- Disconnected wifi card - Verify if not sitting properly
Good luck and good repair.
JM
Add a comment
Game will not download
Add a comment
Add your answer
Aries will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 5
All Time: 330
