4-inch iPhone released in March 2016 with similar hardware specifications to the 6S. Available in Silver, Space Grey, Gold, or Rose Gold with 16/32/64/128 GB storage options. Model: A1662 and A1723
1049 Questions View all
How can I fix water damage on iPhone (more in the description)
I bought an iPhone SE that had water damage. Am I right here that you should put the motherboard in Isopropyl alcohol?
I have seen some videos about all of this. I took the phone apart. First the mother board and then the screen itself. You understand the previous owner said he had repaired the motherboard an the internals but that the screen had 2 white lines. I took the screen apart to see if I saw something. Under the LCD shield lays the digitizer right? It had like a few water marks on it I think. I tried to use a microfiber cloth to get this away but it didn't work. I'm wondering if I can use Isopropyl alcohol to clean the digitizer?
And if anybody knows I would like to know specific what every components in the screen are called and where they sit.
Thanks in advance.
Add a comment
1 Answer
The "digitizer" is the touch panel, which is one and the same as the LCD panel. I believe you are looking at the LCD backlight diffuser, which is between the metal shield and the LCD.
Do not clean it with alcohol, it may dissolve. If it is dirty, you either replace it or live with it.
Add a comment
Add your answer
Daniel Kendel will be eternally grateful.
Past 24 Hours: 2
Past 7 Days: 3
Past 30 Days: 3
All Time: 116
