Model A1181: 1.83, 2, 2.1, 2.13, 2.16, 2.2, or 2.4 GHz Core 2 Duo processor
1203 Questions View all
Number buttons sometimes work
Hello,
I' m facing the following problem:
Using both Mac OS (10.6.8) and Windows 10, the buttons of numbers (1234567890) often stuck. In windows, when I press 5 or 0 then the other numbers unlock and for a few minutes I can continue to write numbers with no problem. In Mac OS, it works only the 0 without any other trick.
Thanks in advance!
Add a comment
1 Answer
I found a solution:
When I hold down for 5sec all of the keys at the same time (1-9), the problem gets solved. Does this mean that is a hardware issue?
Add a comment
Add your answer
tsoump will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 1
All Time: 31
