Repair guides and support for your LG TV.
1342 Questions View all
Picture takes long time to appear
Hello
I have an 42 inch LG Plasma TV (42px4dv) which I have had for several years.
Recently I have been having issues with the TV.
When I turn on the TV, the TV turns on though all the pixels are black. Slowly, pixel by pixel they turn from black to displaying the picture. After around 20-30 minutes, all the pixels display the picture and the TV works fine.
Initially it would take only a minute or 2 to show the full picture, though over time it has got worse... to now taking 20-30 minutes.
I have the issue, regardless what input I choose, and restarting the TV at the powerpoint does nothing . We are at a point where we leave the TV on for most of the day when we are home to avoid waiting for the tv to warm up.
Have any suggestions as to what the culprit may be?
Thank you, Michael
Score 1
1 Comment
Caps were bad on the power board
by
Add a comment
Chosen Solution
@michaelc1172 something with those symptoms is usually indicative of bad caps. I would take the time and check all of them. Pay particular attention to the ones on the power board. They might not necessarily be domed or leaking but may have failed internally. If you have an ESR or capacitance meter you can probably determine which ones.
Score 3
Add a comment
what are caps and where ?
2 Comments:
annaslone2003 caps=capacitors. The ones in this case were on the power board. If you require more help then we need to know the make, model as well as a description of the symptoms for your TV
by
I have similar problem with mine. It has a perfect picture on the top 3 inches of the screen. The rest has lines of color. As minutes go by.......... You can see the picture slowly go down the screen to a good picture.
by
Add a comment
Add your answer
Michael will be eternally grateful.
Past 24 Hours: 6
Past 7 Days: 25
Past 30 Days: 91
All Time: 10,073
