Repair information and guides for the Apple iPhone 5c that was announced on September 10, 2013. Model: A1532, A1456
1233 Questions View all
Wifi siginal iPhone 5c
I just had some repair done to the board and when I got the phone back the wifi only works when I am within 3 feet of my wireless router. I was wondering if you think maybe the antenna has loose connection or something?
Score 1
3 Comments:
Probably wifi antenna capable not plugged in. If I'm correct it plugs under the board at the to left like the other iPhone 5 and higher.
by
I'm going off memory, but I also believe there is a small piece that goes up there as well. Its a little clip looking doohicky that is easy to misplace or not align correctly.
by
It sounds like your wifi antenna maybe loose . I would return it to whoever worked on it.
by
Add a comment
1 Answer
Check the antenna, weak wifi is usually is a sign of a antenna being unplugged where as if it was no wifi at all that would more likely be a bigger issue.
Add a comment
Add your answer
bill will be eternally grateful.
Past 24 Hours: 2
Past 7 Days: 3
Past 30 Days: 3
All Time: 119
