SMD resistor value to the right of the HDMI port
During a HDMI replacement on a PS4, i dislodged and lost one of the SMD resistors to the right of the port. Dose anyone know the value of this resistor.
That's a diode and it actually will work just fine without it.
If you want to replace it your best bet is to get one from a junk PS4 motherboard.
Hope this helps.
Same thing happend to me. Do you need to bridge it?
No...It's a diode...don't bridge diodes
Does anyone have the answer? What is the values of the components inside of that “triangle”?
And what are they? I myself am missing those as well and it’s giving me WLOD
It's not just a diode - it is a VDZT2 series 5,6V Zener diode. It protects DDC bus (clock line) from electrostatic discharges and electrical surges, so it is absolutely necessary to prevent from further and more expensive-to-repair damages. There are plenty of replacements available, eg. CDZVT2T5-6B or CDZFHT2RA5.6B (both available in Farnell).
Saying that the console will work fine without this protection is just asking for troubles - I ‘m really concerned how such an irresponsible advice from @tronicsfix could be marked as Solution?
Good evening,
I want to know how to get or where to download the schematic circuit chart of PS4 and three. If you have, kindly forward to my mail. palmpursenew@gmail.com.
Thanks in anticipation.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 17
All Time: 1,511
