Nintendo's upgraded version of the Nintendo 3DS. It features bigger screens, longer battery life, better pixel density, and a better design.
412 Questions View all
My 3ds lights for a time but never charge
Hi, a few weeks ago I dropped my 3ds xl from about a foot onto hard wood. Since then the charge light will blink when I plug it in, but no matter how long I charge it, the battery never goes up. The parts of the charge port that I thought were damaged looked completely fine and stayed in place, so it might be losing the charge somewhere in the motherboard, but I have no idea how to find the problem or how to fix it. Any suggestions are appreciated. Thanks in advance . :)
Add a comment
1 Answer
On the bottom of the 3DS console, there are 2 small screws. Under them, you can find the battery compartment. Try removing the battery and holding in the power button. If this does nothing try replacing the battery as they are relatively cheap. Opening this cover will not void your warranty but if the system is relatively new if that doesn't work send it in for repair as it will be under warranty.
I cant really think of anything other than a connection error that would cause this so if your system is not under warranty you can open the screws below the cover previously described. Inspect the board for any broken solder joints or loose wires and connections. You can simpily fix the loose connection by resoldering this stuff but be careful as it is small and delicate.
Add a comment
Add your answer
Guilherme Giannoccaro do prado will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 68
