The Nexus 6 is an Android phone developed by Google and Motorola released in 2014 with a 6-inch display.
Voice call doesn't work after water damage
Hello,
My Nexus 6 got water damaged, then after a few days and a hard reset to turn back on, but now whenever I use voice call on Whatsapp / Hangout / normal phone call, the app crashes.
Is this something that can be fixed? Is it worth it?
Add a comment
1 Answer
Chosen Solution
Hi,
Liquids and electronics, especially when the electronics are powered on are not a good mix. (Mobile phones are always powered - the battery supply is never isolated from the systemboard and most liquids are a good conductor of electricity)
The corrosion of the circuitboards caused by the mix of water and electricity, (water alone is bad enough) and the possible damage caused by electrical currents flowing where they shouldn't because of the water will continue until the power has been removed and the corrosion has been removed and stopped by the correct cleaning procedure.
The best thing to do is remove the power as soon as possible and then follow this guide on how to clean the circuitboards. The battery will most probably have to be replaced as well.
Hopefully you may be able to save it.
Electronics Water Damage
Score 2
Add a comment
Add your answer
Karen WONG will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 7
All Time: 141
