The March 2015 update of Apple's 13" MacBook Pro Retina Display, model A1502, features fifth-generation Intel Core i5 and i7 processors and introduces the Force Touch trackpad.
1185 Questions View all
Laptop only works when plugged in
I spilled a bit of water on my computer and ever since everything has been working fine, except I can only use my computer when it's plugged in. The battery icon at the top says 100% and the light on the magsafe is green. I ran a battery diagnostic and it says everything is working fine. If I'm using the computer and the cord comes unplugged it just shuts off.
Like I said, everything else is working fine, it's not running slow or getting hot. What parts could be the issue?
Update (09/01/2016)
Oh I should add that I already tried an SMC reset to no avail.
Add a comment
Most Helpful Answer
Give this gem of an app a try to check things out: Coconut Battery. Its a free app! Snap a screenshot of the main screen and if you can try pulling the power cord while the system is running to snap a second capture. Post them here so we can see.
Score 3
Add a comment
You need to replace the battery as im on the same with my samsung laptop and i got a new battery and now it all works fine , good luck
2 Comments:
@Coco - Very different animal ;-}
As this was water damaged it could be a few different things. Doing some level of diagnostics would be a smarter direction here.
by
I agree completly
by
Add a comment
Add your answer
Kate Morics will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 1
All Time: 1,102
