Why is my phone not starting after factory restoring
i have chosen the factory default restore now my phone is on with only apple sign
Use iTunes and select the sync tab. Re-Sync the phone to your computer and the firmware should be updated. Do not interrupt this sequence. Once the phone is done it should notify you via iTunes and then you an disconnect and use the phone as normal.
Cheers:
Patrick Busby
hei nettsamfunnet kjøpte en iPhone 16GB og nar nettsamfunnet slår hiet in Står Det en usb kabel Som Peker in no san itunes også eh Det en plate under sår Det itunes
A "Erase All Content and Settings" or the very different "Factory Restore" in either case a FAIL with a "White Apple on the Screen" the only fix I know of is a DFU restore. Not a Restore Mode restore or a Recovery Mode restore. But a true DFU restore.
Brad
Not sure what you're getting at. He has the apple AFTER a restore settings... He isn't trying to fix the apple with restore. If you're advising dfu then maybe you should tell him how to do this... Not everyone who comes to ifixit knows these terms.. It'd help anyone browsing for help too!
Past 24 Hours: 2
Past 7 Days: 2
Past 30 Days: 2
All Time: 2,695
2 Comments
mdkasi, is this still a problem or did you get it fixed?
by oldturkey03
Factory restore ( from settings/general) can take a few hours according to apple. As long as the progress bar is moving along (slowly) don't panic
by pollytintop
