Released on July 21, 2011. Core i5 or Core i7 Processor. Thunderbolt. This unit is also used to run the Mac mini Server configuration.
204 Questions View all
Mac Mini Mid 2011 fan At full speed although says 0rpm
I recently purchased a mac mini mid 2011 on the cheap because it came without a harddrive.
Its currently running the macOS Sierra public beta off a 2tb external hdd which is working surprisingly well however the fan is spinning at full blast which is generating alot of exhaust noise.
Ive opened it up and noticed that the sata cable that connects to the internal drive is also missing.
My question is, Would replacing this cable and installing an internal HDD fix the fan issue or does the fan itself need to be replaced?
Ive tried using smc fan control and similar apps to no avail and get a RPM reading of 0 from the fan.
Ive also run AHT and returned the following error: "4M0T/1/40000002: Exhaust - 0"
Many thanks in advance for replies.
Add a comment
1 Answer
Most Helpful Answer
Sounds like someone broke a component on the logic board when they were in the system.
The logic board has a small section sticking out at the front of the board (you take the board out from the back) which in the process of installing can snap off one of the components. The part is part of the fans tach logic has come off or the fan socket was damaged (on the far left in the image)
Take the board out and compare it to this image: Mac Mini Logic board.
Does it look OK?
To take the logic board out follow this IFIXIT guide: Mac Mini Mid 2011 Logic Board Replacement through to Step 17.
As the drive and its cable is missing you'll need a few parts. I would recommend you get this kit: Mac Mini Dual Drive Kit just get the kit without the tools if you have them. That way you'll get all the needed parts to put in a drive (just ask for the lower bay - primary drive cable instead)
Mac mini Dual Drive Kit Image
Product
$26.99
Score 2
Add a comment
Add your answer
Ryno will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 5
All Time: 520
