Everything you need to repair your iPhone yourself! From the newest iPhone 15 lineup, all the way back to the original iPhone 2G released in 2007, iFixit has free repair guides and disassembly information for every single iPhone, as well as the best replacement parts, tools, and tips in the galaxy.
36476 Questions View all
Are screws required for testing iPhones
After removing a logic board on any iPhone to do some repair work, is it essential that all the screws be back in the phone to perform testing?
I'm curious, because we've been getting into iPhone repair, and when we're re-assembling the phones, we've been running tests without all the screws holding the logic board in to make it easier to remove if we need to.
Add a comment
Most Helpful Answer
Its smart to put all the screws back before connecting the battery. Some serve as grounds.
Score 2
1 Comment:
I thought that might be the case, because we've been getting some weird screen issues with crazy lines in them. So we started putting screws back in, but wanted to see if there was any specific reason. thanks!
by
Add a comment
No there not i fix all phones but with all the iphones i do about 10 a day some times less but i take the logicboard out and the sheilds off but i do tape the back off before i put the logicboard in and the top screw to test that ive fixed the problem and if not i take apart remove the chip replace and try again untill i get it right then once its done and checked then i put all the sheids back in and put all the screws back in place them put all together and one last check then back to the customer,? But if you not confident on what your doing then always put everything back were it came from,?
Score 1
2 Comments:
thanks for that!
by
No you put all the connections on then the phone will work fine with out screws to test then if fine put all the screws in the exact place they came from,?
by
Add a comment
Add your answer
dollartripclub will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 7
All Time: 175
