Repair information and guides for the Apple iPhone 5s that was announced on September 10, 2013. Model: A1533, A1453, A1457, A1528, A1530, A1518
iPhone Reboot loop with blue patch
I just removed my rear camera following ifixit's guide and everything is working so far.
I lost one of those 1.7mm screws for the metal bracket, but it still works properly until 2 hours ago, when it shutdown by itself and is stuck in a reboot loop with a blue patch that covers 70% of the screen, originating from the middle.
Is there anyway to save my iPhone ? Will buying the missing 1.7mm screw help ?
I doubt it is a misplacement of screws as my phone is able to work till 2 hours ago.
Regards,
Lost Soul
2 Comments:
Did you try re-opening your phone to see if anything was knocked loose? Those brackets hold the press connectors in place, so if it wasn't entirely screwed down then it would be more likely that one of them could be disconnected.
by
I re-opened the phone and found that the 3 connectors beneath the bracket (Digitizer, LCD, Sensor) is connected to its respective sockets. I reseated all connectors but the issue still occurs randomly. Sometimes it can be working fine for a few hours, and then the reboot loop strikes again. Guess I will buy the iPhone 5S screw set and replace that particular 1.7mm screw and hope it solves the problem..
by
Add a comment
1 Answer
If you mix up the bottom left screw on the LCD connector plate you can scratch off the board under there which will cause this to happen. It's crucial that you don't mix up those screws, and if you do just don't put in the bottom left one just to be safe.
Add a comment
Add your answer
Daylen will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 9
All Time: 252
