Repair information and guides for the Apple iPhone 5s that was announced on September 10, 2013. Model: A1533, A1453, A1457, A1528, A1530, A1518
3530 Questions View all
Replacement screws, how do I measure them?
Hello guys, this time I am here to know if there is an easy way to measure the screws in a set of replacement screws for iPhone 5s.
Thing is I only need the ones holding the home button bracket (1.4mm #000 phillips); the ones holding the battery connector bracket (1.6mm #000 phillips); the ones holding the front panel assembly cable bracket (1.7, 1.7, 1.3 and 1.2mm #000 phillips); the ones holding the earpiece speaker bracket (4.0 and 2.3mm #000 phillips); and the one securing the back of the display assembly to the LCD plate shield (2.7mm #000 phillips).
So I need to know which one is which.
Any help?
Thanks.
Score 1
Add a comment
Chosen Solution
@caraneday looks like they have been measured by the total length. The only way to measure them properly is by using a vernier caliper. Not an expensive one time investment....
Score 1
5 Comments:
@oldturkey03 thanks, I'd thought the same but... how accurately would that be? I mean, there are 1.2 and 1.3mm; and the caliper has an error range, so a 1.2mm might be seen as 1.3mm right? :(
by
Sure it could but that's a bit high for a vernier error rate. If that would happen then all of them would measure longer. It's never easy to get all of it right when we did not have a chance to sort the screws during dismantle or if they get mixed up. Toughest part of that job......
by
@oldturkey03 any brand you suggest? a digital ideally :P
by
Not sure where you are locatesd I'd go with a digital rweadout since that will speed up your work and you do not have to struggle with either metric or imperial
by
@oldturkey03 thank you so much!
by
Add a comment
you’ll need to pay attention to the screw diameter. and a digital caliper such as Harbor Freight sells will save you a lot of pain an guessing.
Add a comment
Add your answer
Carlos will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 3
Past 30 Days: 11
All Time: 1,669
