The Apple iPhone 5s was announced on September 10, 2013. Repair of this device is similar to the previous models, and requires screwdrivers and prying tools. Available as GSM or CDMA / 16, 32, or 64 GB / Silver, Gold, and Space Gray.
4098 Questions View all
Do we have an answer to "Ghost Touching"/Screen Freezing for the i5S?
I have a 5S, which goes haywire and the screen freezes intermittently.
Ghost touches galore!
I tried 3 different screens all with the same result, this is obviously an issue on the logic board.
Does anyone have a definitive answer to what is going on here?? Does anyone have a definitive answer on how to fix this?? Very irritating problem.
Comments:
No Water Damage On Device.
by
Add a comment
1 Answer
Chosen Solution
I have fixed it a few times on iPhone 5 / 5s because of liquid damage being present on the board. In particular near the front panel connectors under the black plastic adhesive cover thingy.
I used some 99% isopropyl alcohol to clean the corroded / liquid damaged affected areas. Check the LCI (Liquid Contact Indicator) on the logic board if it's red or not. There are two easily visible ones when you open up the phone. If it's red the phone has had liquid gone internally inside the phone. If it's white then no liquids have gone into the phone.
Score 1
Comments:
Theres no Liquid damage on the phone.
by
Add a comment
Add your answer
Stavros Pehlivanidis will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 3
All Time: 169
