Repair information, troubleshooting tips, and guides for the sixth iteration of Apple iPhone, announced on September 12, 2012. Model: A1428, A1429
2522 Questions View all
Power button (sleep/wake) stopped functioning after battery replacemen
Completed the iPhone 5 battery replacement and now my power (sleep/wake) button no longer functions. Is there a connector I might have accidentally dislodged while removing/reinstalling the 3 connectors near the power button? Or some other damage I may have done?
Thanks
-Ray
Add a comment
1 Answer
Chosen Solution
If you pryed the top part of the battery then you probably have partially damaged the sleep / wake ribbon cable flex assembly.
There is one smaller connector near the 3 front panel connectors, that one is for the power / sleep or wake button along with volume and vibrate.
Note that if the battery isn't glued down it can damage the cable too. The cable runs right under the upper part of the battery.
Guide to replace the part:
iPhone 5 Audio Control and Power Button Cable Replacement
Where you can buy the part:
iPhone 5 Audio Control and Power Button Cable Image
Product
Score 3
3 Comments:
I just confirmed that the volume buttons are not working either, so you are likely correct. I'll disassemble it again tomorrow to see if I can confirm.
Thank you
by
My volume buttons are ok, but on/off and home buttons won't work. Any idea?
by
Check the home button ribbon cable on the display assembly to see if it has any physical damage like tear on it.
Also check the charger port ribbon cable if it's ripped or the home button connection golden prongs that contact with the home button to see if they are bent / missing / damaged.
Vol up + Down, Vibrate connection, power button are all part of the same volume button cable. You will need to replace it as the whole cable since any one of those requires it to be replaced anyway.
by
Add a comment
Add your answer
Ray Toscano will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 1
All Time: 81
