battery not working on the MacBook Pro
Hi, I have removed the battery in the MacBook pro 2013 .. to get to the mouse pad,
and now the battery does not work it will not turn on the MacBook it did have around 50% of charge !
2 Comments
Why did you need to get to the mouse pad? What was the original problem?
Did you unplug the battery before doing anything else? How did you pry out the battery? Is it damaged in any way?
by Rany
Yes unplug the battery, I did remove the battery to get to mouse pad has some times it would freeze ? if you move the MacBook ie twist the base is little mouse pad started to work? The middle battery got a bit bent !
by EON
