Repair information and guides for the Apple iPhone 5s that was announced on September 10, 2013. Model: A1533, A1453, A1457, A1528, A1530, A1518
3530 Questions View all
How to reattach 5S glass to the inner frame (no battery swell)?
The picture shows an iPhone 5S glass unit, with the glass is detached from the thin plastic frame. What held the two parts together originally, and what's the best way to repair?
I'm considering thin double sticky tape, but there seems precious little area for the tape to grab to. All parts of this phone work fine.
Score 1
Add a comment
Chosen Solution
First of all youre very lucky that its working!!!! Be carfull about the wire connections and dont fold them
For sticking all together the best solotionis to use uv glue which is a liquid glue and its advantage is that its a glue and after drying you screen is in right position and not higher thanthe frame comparing to tape ,but if you can find a thin tape thats ok. Remember to unscrew back metal plate then apply glue
Score 1
Add a comment
Most Helpful Answer
These screens are usually held together using a special adhesive, the name of which I forget at this present moment. In some cases a standard 3M tape mold may fit nicely, but I've seen a lot of refurbishers use a bulk liquid adhesive solution they apply (in globs) to the screen to ensure a seal.
If you're trying to re-assemble yourself, I'd say be extra cautious about trying to "hack" a solution when this really calls for a replacement screen. If you're trying to have fun/experiment, I've heard B-7000 is quite effective. I've used it myself a few times but it does leave a mess if not applied right.
https://www.amazon.com/AOMAG%C2%AE-Cryst...
Score 2
1 Comment:
Yep. I've used B-7000 on a few clients iPhones where the glass has pushed up from the frame due to them repairing it somewhere else ending up with a cheap quality screen or they dropped the phone. Works exceptionally well.
Even if you make a mess you just need to at least get the glue between the glass and the screen frame, just make sure you don't over do it and use tape to hold the screen down temporarily to let it set well over time.
Then take the tape off carefully of course from the screen side first so you don't pull the glass up weakening the glue.
by
Add a comment
Add your answer
Bryce Nesbitt will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 11
Past 30 Days: 13
All Time: 138
