This Power Mac G4 has Mirrored Drive Doors.
80 Questions View all
Where do you fix or buy power mac G4 power supplies
how or where do you fix or buy power mac G4 power supplies, Samsung LQ3352ABPoWB, apple pin 614-0224
Update (08/12/2016)
Sorry for the delay, just had world wind of unexpected etc..
Here is the pictures of the psu now finally removed from G4 MDD
add'l zoomed in pictures
do I need to remove fans so I can
lift up housing to get other view?
----- went ahead and unscrewed fans to get other views
Score 3
12 Comments
Which machine does this go in? I may have it. There is a new one here: http://www.ebay.com/itm/New-In-Box-Apple...
I think this is a part for an MDD not the machine posted.
by
@itspos what have you checked, what machine does it belong to, what are your abilities?
by
This is for a powerMac G4, it shut off completely - no power. 1st: I replaced internal battery- nothing. Next,I tried resetting the PMU/cuda switch - nothing. 3rd tried removing battery and resetting PMU/cuda switch + power button, waiting then re-inserting 1/2 aa battery - nothing.
by
I have added hard drives and ram to computer but haven't gone much further than those ... but willing. Spent all morning trying to read about how to ground myself before attempting to remove power supply. Still reading
by
PowerMac G4 model M8570
by
Show 7 more comments
Add a comment
Most Helpful Answer
@itspos check the fuse. Most common failure on these PSU's are
-mains cap shorted
-bridge rectifier shorted
-power MOSFETs shorted
So you do want to take it apart and post some high res images with your question. For that, use this guide
Score 3
16 Comments:
okay I will take it apart and post pictures ... I'm game for learning anything I can to fix this "puppy" ...
by
Here's how to remove it: Power Mac G4 MDD Power Supply Replacement
UPDATE 7/26/16
Looks like it is Apple part # 661-2816
This one: http://www.powerbookmedic.com/Power-Mac-...
by
Not sure if you had a chance to look at pictures of psu opened up.
sorry for delay, just unexpect family stuff ... any insight would be helpful.
Thanks!
by
@itspos no problem. Had some family crisis myself. Bad week for that. Anyhow is there any chance you can repost the images after you blow the dustt off the PSU and have the images in a larger format? Hard to see with these old eyes:-)
by
I can re-shoot after dusting, but not sure how to make cel photos any bigger at this time. I will shoot in sections as large as I can. It will take a few days.
If computer was working I could enlarge them.
by
Show 11 more comments
Add a comment
https://www.ebay.com/itm/REPAIR-SERVICE-...
Add a comment
With these older machines its usually best to source another machine for dirt cheap and swap parts between them. Otherwise eBay might have the poeer supply you are looking for.
Add a comment
These PPC G4 PSUs are so old now that even if you did find one on Ebay chances are it will be on its last legs anyway.
So a guide to refurbish a PSU would be awesome as so many g4s could be revived as the PSU is the most common fault.
I have 2 x 933 Quicksilvers that I use for a Pro Tools TDM rig but both have PSU issues now and G4 QS 344w PSUs are as rare as hens teeth.
Even if the guide was split into sections ie part one : replacing mains fuse
Add a comment
Add your answer
Earth Bound Traveler will be eternally grateful.
Past 24 Hours: 9
Past 7 Days: 13
Past 30 Days: 18
All Time: 1,034
