Repair information and guides for the fifth generation of iPhone. Model: A1387
2201 Questions View all
iPhone 4s showed apple logo, then gone, wont connect to itunes
I have a Iphone 4s that I put a new battery in. I plugged it in to a charger after that, the apple logo came up then went away. I then plugged it into the computer (windows xp, without itunes), it connected fine and the computer said it was in dfu mode. So then I plugged it into a newercomputer with itunes, it connected for a second then disconnected. If I got the charging cord in the right spot it would stay connected for a little longer never more than like 5 seconds. The phone gets warm while on the charger.
Add a comment
1 Answer
Most Helpful Answer
It sounds to me like you either have a faulty battery or a bad charging port. I would try another charging port to see if this fixes the problem. If not, I would send the battery back for credit and try another battery. The possibility of getting a bad li-po battery is slim but it does happen from time to time.
Score 1
5 Comments:
Okay thank you very much!
by
Is the charging port replaceable? or is it the dock connector?
by
It is the charging flex cable. The 4 series has a different design, obviously, from the 5 and 6 series iPhones but they all have a "flex" cable that has the dock connector, microphone, etc... You should be able to find one on www.ifixit.com or Amazon for about $10-15 or less.
by
is it this [linked product missing or disabled: IF115-011] or this iPhone 4S Dock Connector ? thank you
by
Add a comment
Add your answer
Allan Edwards will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 2
All Time: 56
