iPhone 6 on/off loop
I dindt want my iphone to be jailbroken mor so i factory resetet it. it went out off battery and when i charged it it just turining on and off evry 5-10 seconds.... help?
Plug it into the laptop/pc, then put it into dfu mode. Should prompt a restore
Press and hold both the sleep/wake and the Home button until the screen goes black. Release the sleep/wake button but continue holding the Home button for about 20 seconds. After about 20 seconds, you should see your iPhone pop up in iTunes in recovery mode, asking for a restore. Your iPhone LCD should remain black
if it is a bug then idk, but it could be a physical issue with the battery not being plugged into the whatamacallit. my iphone 6 had the battery shaking around in it, and it would show the apple logo then turn off over and over. i took it apart, held the the thing that the battery connects to against the battery connector, and tried it again, and it worked. so try that.
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 1
All Time: 89
