dryer keeps running after timing out
Dryer keeps running after it times out until door is opened and still runs when door is closed again even when turned off
Please give us your model number.
Timer
Located in the control console of the dryer the timer consists of a small motor connected to a series of gears that rotate cams, which turn electric contacts off and on inside the timer. The timer contacts control the dryer motor as well as the heat circuit and the timer motor itself. A defective timer motor or a defect in the timer’s electrical contacts can cause the timer motor to fail and the timer will need to be replaced. The contacts can be checked for continuity with a multi-meter. This test should only be made when the dryer is unplugged.
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 7
All Time: 492
