Revamped version of the iPhone 3G with faster processing speeds. Repair of this device is similar to the 3G, and requires simple screwdrivers and prying tools. Model A1303 / 8, 16 or 32 GB capacity / black or white plastic back.
How to remove adhesive glue?
Hi everyone,
I'm replacing the glass of my iPhone 3GS because it was cracked. I have separated the glass from the bracket with a heat gun. But how do I remove the glue residue that is left behind?
Thanks,
naf
Add a comment
Chosen Solution
I use isopropyalcohol as it's not likely to cause liquid damage to any parts and either a small flat head screw driver or plastic spudger tool to scrape it off. it's fiddly and annoying but you can also just use your fingers to roll it and pull it off.
Score 1
Add a comment
Most Helpful Answer
With a q-tip, try using a bit of Goo Gone or Goo Off. A small amount goes along way. After you've removed the residue, use another q-tip with ALCOHOL to remove any oils left behind by the Goo Gone/Goo Off. That's what I do for all my electronics.
Score 2
2 Comments:
+ for the goo gone
by
Goof off and goo gone are NOT suitable for plastics. It will damage it
by
Add a comment
Add your answer
naf will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 3
Past 30 Days: 13
All Time: 5,909
