replace a a1212 with an A1261
hello, I have a macbook pro with the logic board a1212 broken , I would like to know if i can replace it with a A1261 (to have such a powerful pc).
thanks
thanks
No sorry they are not cross compatible , for starters the screens are different a1212 uses CFL bulb , while the a1261 uses LED bulb.
thank you, and whit a1229?
or any more powerful?
A white screen usually indicates a failed hard dive. Try disconnecting the drive from the logic board and booting from the original system installation optical disk.
you are right, thanks a lot!!!
Then you accepted the wrong answer ;-)
Past 24 Hours: 1
Past 7 Days: 2
Past 30 Days: 2
All Time: 142
4 Comments
or another more powerful, as the model a1229
by davidegatt
Why do you think the logic board is broken?
by mayer
the screen remains white after power, and did not work any recovery procedure (pram reset etc.)
by davidegatt
by davidegatt
