Model A1419 / EMC 2806 / Late 2014 or Mid 2015. 3.3 or 3.5 GHz Core i5 or 4.0 GHz Core i7 (ID iMac15,1); EMC 2834 late 2015 / 3.3 or 3.5 GHz Core i5 or 4.0 GHz Core i7 (iMac17,1) All with Retina 5K displays
573 Questions View all
Adding a 2nd Hard Drive to Late 2014 iMac Retina
I have a Late 2014 27-inch Retina iMac with a 512 GB SSD. I'm running out of space and would like to add a second internal hard drive. I already have a 4 TB drive that is less than a year old that I pulled from my older iMac when the iMac died and would like to use that drive if possible. So two questions: Is it possible? If possible, do I need a special cable?
Add a comment
1 Answer
Most Helpful Answer
It definitely is possible, but it's a tough and risky job. Please read through the excellent answer Dan gave in a previous similar question, he mentions all pros and cons carefully.
Adding a 2nd SSD. Are cables included?
His suggestion at the end just to opt for an external thunderbolt 2 enclosure makes so much more sense, that I can only fully agree with him. Please consider the 'easy' way out before attempting a risky operation :)
Score 2
Add a comment
Add your answer
Steve Tompkins will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 2
All Time: 1,284
