Released on July 21, 2011. Core i5 or Core i7 Processor. Thunderbolt. This unit is also used to run the Mac mini Server configuration.
204 Questions View all
Bluetooth and WIFI problems after SSD Install
Hello everybody!
I was install SSD to my Mac Mini 2011. Everything goes fine, cause ifixit install guide is awesome.
But after assembling my Mac and power on it, I can't use bluetooth and wifi. Mac reports Bluetooth: Not Available in upper bar.
System Profiler says nothing about bluetooth adapter installed. In WiFi (under Network section) I see WiFi Airport.
I think all cables installed and connected properly, but Mac don't think like that. SMC and NVRAM reset doesn't help me after all.
Any thoughts? Maybe airport/bluetooth plate was broken?
Thanks a lot for any help! (sorry for my english)
Add a comment
1 Answer
Chosen Solution
Sounds like the AirPort ribbon cable either is not connected or got damaged somehow.
You'll need to open the system up again follow this IFIXIT guide: Mac Mini Mid 2011 AirPort/Bluetooth Board Replacement. Follow the guide up to Step18. You can see the cable at this point for a more detail of the cable look at Step21 & 22.
Score 1
1 Comment:
Thanks a lot! Ribbon cable was disconnected somehow.
Everything's fine now!
by
Add a comment
Add your answer
egorrevenga will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 2
All Time: 1,285
