Repair information, troubleshooting tips, and guides for the sixth iteration of Apple iPhone, announced on September 12, 2012. Model: A1428, A1429
2522 Questions View all
How to see a motherboard problem
Hi
I've just changed my battery in my iphone 5 but after that, the new battery unload really fast.
So then l return to the place where l bought it and the saler said me it is a problem with the motherboard.
But now l would like to know how to recognise a motherboard because l feel like the saler didn't put a new battery but one that have been already used...
Thank you
Eric
Score 1
Add a comment
Most Helpful Answer
it definitely sounds like a problem on the motherboard with a chip called Tristar or U2. The problem is that this chip is draining more power than what you can put into your phone. Therefore replacing the battery doesn't address the issue at hand.
This is definitely a replaceable part, and is a very common problem. go to a repair shop that does micro soldering and they should be able to help you out.
If you want to give it a go yourself ill point you in the right direction on what to do, but it requires a lot of expensive equipment and even more time learning how to do it.
So I wouldn't recommend doing it if you haven't done it before.
A motherboard is basically a PCB/Circuit board that is inside your phone with thousands of microscopic sized components soldered to it. There is no way to see a motherboard problem, only ways to diagnose a motherboard problem. Kinda the same way that you can't see DNA but you can diagnose problems with it.
My biggest issue is why the repair shop you first went to didn't see the problem in the first place (As it only takes 60 seconds to test for) and refer you else where. We get customers coming in all the time asking for battery replacements and only about 15% actually need them, the rest have the U2 Problem mentioned above.
I hope that answers all your questions.
Melanie
Score 2
1 Comment:
Hi. I have the same issue. My phone also feels like it heats up. Also, if I press the power button and leave it on the table for about 3 minutes 30 seconds, it shuts down completely (and needs to be restarted). Could you guide me in the right direction because hte store I went to replaced the battery and couldn't fix the issue either? (iphone 5s in my case)
by
Add a comment
Hey mate can you help me when i do record in the front camera and when i done then i review and the result is low sound i can’t really hear clearly the sounds not like in the rear camera just normal my problem is its just the front HD camera when i record please tell me if you know what is the issue
1 Comment:
Without more details like the model of phone you have, the only thing I can suggest is try cleaning the microphone ports on your phone
by
Add a comment
Add your answer
ericbuya will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 1
All Time: 6,996
