Repair information, troubleshooting tips, and guides for the sixth iteration of Apple iPhone, announced on September 12, 2012. Model: A1428, A1429
2522 Questions View all
I don't know if it works
I took the screen off of my iphone 5 to see why the home button was unresponsive. I should add that i never messed with the home button. After i was finished I put the screen back on the phone but it wouldn't turn on. In an attempt to see if the phone is broken I plugged the phone into my computer and the computer recognized it but it wouldn't let me see the files. Also in case you say to message your phone and see if it makes a noise I put my phone on silent because ten minutes before doing this I was at a family members house and didn't want it to go off. Is it just the display or is it the whole phone? Please help!
Score 1
Add a comment
Chosen Solution
This sounds like the screen cable is not correctly connected or was damaged when you removed the screen . I would open the phone again and closly examine the ribbon cables that attach the lcd and the digitizer to the logic board remember there are three to connect there is also the camera
iPhone 5 Screen Replacement
Step 15 of the guild shows the connectors . Look closely at the connectors on the board and the cable ends for damaged pins. they should snap together with ease if aligned right if they do not go together easily theres a problem with the connector. The reason you couldn't access files is you need to sign into the phone to gain acess you need to fix the screen to log in . As for the home button and power button @jbrennan51 has covered that in his answer
Score 3
17 Comments:
I need to be more detailed in my answers. Great explanation of how to fix issue @jimfixer
by
thanks for the feedback. ill look at it more closely
by
@jimfixer I took a closer look at the cables and the connector on the board and i didn't see any damage done to either of them
by
then reconnect and make sure they snap together completely
by
alright they are connected
by
Show 12 more comments
Add a comment
I would review these two step by step guides on iPhone 5 power button replacement and home button replacement. I missed one thing when repairing a phone and ended up with no power.
iPhone 5 Power Button Replacement
iPhone 5 Home Button Replacement
iPhone 5 Home Button Image
Guide
Difficulty:
Moderate
45 minutes - 2 hours
iPhone 5 Power Button Image
Guide
Difficulty:
Difficult
Score 1
4 Comments:
Thanks for the response! although i forgot to add that i never touched the home button
by
Your welcome Declan.
by
so now that you know its not the home button what do you think the problem is?
by
Ive been watching your posts keep up the good work and welcome to I fixit @jbrennan51
by
Add a comment
Add your answer
Declan will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 2
All Time: 158
