A television game console produced by Sony Computer Entertainment, also known as PS4. First announced February 20, 2013 and released November 15, 2013.
1697 Questions View all
lagging controller after optic drive replacement?
Replaced optic drive successfully. Now the controller lags terribly. I've read that it's something wrong with a Bluetooth component on the motherboard. It's just weird because I barely touched the MB when I replaced the Drive. But any help is appreciated. Thanks
Score 1
1 Comment
Anyone? ....
by
Add a comment
1 Answer
Chosen Solution
Sounds like you have a problem with the WiFi antenna. First, check to make sure that the cable is plugged in under the power supply as it should be. If that's OK then you'll also want to check the large metal part that is on the disc drive. Check to make sure that the small wire is still soldered on to the large metal piece. I suspect that you may have forgotten to plug the cable back in under the power supply but it very well could be broken on that large metal piece in the front as well.
Score 1
Add a comment
Add your answer
Austin Harris will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 52
